marine injecter
Old May 15, 2009 | 04:02 PM
heins's Avatar
Default marine injecter
im looking at buying a set to put in my truck.. my question is that would they be a good injecter to put in?
Old May 15, 2009 | 04:04 PM
nmlakerat's Avatar
if you have marine pistons.. you have to make sure they have the correct spray patern or they will cause to much heat and smoke
Old May 15, 2009 | 04:29 PM
12valvetater's Avatar
they are a dirty injector but you can make good power with them many people have and will continue to just make sure you have plenty of airflow
Old May 15, 2009 | 11:35 PM
94cummins12v's Avatar
you can also use different copper washers between the head and injector to make them spray into the bowl rather than around it, thats why i had so low egts when i had the 370's
Old May 16, 2009 | 11:46 PM
djwhonda92's Avatar
they will give you power...! but if you want to reach 500+ HP efficiently then you need to go with a better injector.. like the DDP 90 horsepower. they are expensive but worth the money. i am currently running the 370 marines.. but i am going to upgrade asap
Old May 17, 2009 | 11:02 AM
hey djwhonda92 try a different injector washer in your injectors i know when i traded mine out i notice a good 100* drop in egts and a decline in smoke
Old May 17, 2009 | 12:13 PM
xzaq103's Avatar
FormerVendor
You can fin injectors with the proper spray for just a little more and mpg will more than pay for itself.
Old May 17, 2009 | 05:40 PM
94 12valve's Avatar
bumping your timing will also help with marine injectors 16.5* - 17* works well with 370's
I agree spend the extra $150 and get a good clean injector thats gonna make more power, run better, and save you fuel.
Old May 18, 2009 | 04:26 PM
purch's Avatar
what is the best injector for the 12 valve to make more power for towing and save fuel
Old May 18, 2009 | 04:31 PM
xzaq103's Avatar
FormerVendor
215s
