6.0 IS SICK AGAIN
Old May 14, 2009 | 08:53 PM
ace1's Avatar
Default 6.0 IS SICK AGAIN
IM NEW TO THIS SITE NEEDING HELP... THE FORD IS A 2003 ONE TON 6.0, IT HAS HAD THE HEADS OFF TWICE, ONE TURBO & INJECTORS REPLACED. NOW THE OTHER DAY THE ENGINE OIL STARTED FILLING THE COOLING SYSTEM, BUT IT NEVER RAN HOT OR ANYTHING WIERD. I PULLED THE RADIATOR, & THE COOLING SYSTEM IS A MESS!!
ANY IDEAS? THANKS!
Old May 15, 2009 | 02:04 AM
yankeeflatsdiesel's Avatar
your oil cooler took a **** it sounds like, by the way is it turned up such as edge or other programmer? little brother has a sick.0 too and lots of headaches to go with it and his has an edge on it. has been in and out of shop several times in past two years and lucky for him he hooked up with a guy that is a powerstroke guru and and is the only one he will let work on it.
Old May 15, 2009 | 04:00 PM
txredman's Avatar
Texas Mafia
Trade it on a Dodge - thats what I did with my 03 6.0!
Old May 15, 2009 | 06:51 PM
ace1's Avatar
THIS IS MY BUDDYS TRUCK, IT IS ALL STOCK, BUT HE IS SICK OF THE BREAKDOWNS, LOL.
I DRIVE A DURAMAX AND LIKE IT.
WORKING ON THAT FORD IS AN ACT OF GOD!!
ILL CHECK INTO THAT OIL COOLOR, WHERE IS IT LOCATED AT??
THANKS
Old May 15, 2009 | 08:18 PM
HeavyAssault's Avatar
Find the turbo and come forward about 5 inches and look down under all the stuff.
If it's the OC you got to tear the entire top accessories off. Aparently the heads were not decked correctly the second time around.
Old May 16, 2009 | 05:48 AM
hock6.0's Avatar
my oil cooler blew a hole in it around 138,000. my mech spent a hole day running and flushing the coolant system with water and dawn dish detergant. when i got it back i ran it for a month or so with coolant in it than flushed it again with water and dish detergant 2 more times. it is a royal pain to get clean. Had to flush it again several times 8 months later cause the ford garage mixed anti-freeze and my coolant started to turn into a thick chalky lookin sludge.
Old May 19, 2009 | 11:54 PM
BLACK_06POWERSTROKE's Avatar
i had pondered on that i just cant get the feeling for a dodge
Old May 25, 2009 | 06:34 PM
Big Angry Hillbilly's Avatar
You can't deck a 6.0 cylinder head.
There's a TSB for flushing cooling systems contaminated with oil due to oil cooler failures. We've got a new chemical that you use along with Simple Green...and WOW does it ever work. Just don't breathe the fumes.
Old May 28, 2009 | 09:39 PM
ace1's Avatar
o.k. i got it apart now & the intake & egr cooler are off. is the oil cooler that unit right under the oil filter?
Old May 30, 2009 | 10:51 PM
Yes. DO NOT BUY THE "REBUILD" kit from Ford. You want the whole oil cooler assembly, as well as the 6C683 (basic number) screen that goes underneath it.
