Cams
Old May 14, 2009 | 08:49 PM
turbo20psi's Avatar
Default Cams
I like to change my cam in my truck. Has anyone changed there cam in there truck and what type seems to be the best.
Old May 14, 2009 | 09:10 PM
sstockton's Avatar
F1 helix2's are a pretty awesome cam and the way to go from everything I've heard and the research I've done. Im putting mine in on Saturday morning, then have some other buttoning up to do on the truck over the weekend. Fresh trans, Tuning for the twins etc... should have it up and going by monday though. I'll give you a report on what I see with it.
Helix 2:
Intake Lift .271"
Intake Duration 188.5 degrees @ .050"
Exhaust Lift is .289"
Exhaust Duration 208.5 degrees @ .050"
Lobe Seperation 110.3 degrees
Stock:
Intake: 159* .235" lift
Exhaust: 206* .297" lift
Lobe seperation 107.5*
Hope this helps, there is also some information on the Max spool 2.5+ cam as well that I can probably round up.
Sean
Old May 15, 2009 | 09:51 PM
turbo20psi's Avatar
Helix 2:
Intake Lift .271"
Stock:
Sean
Thanks sean, let me know how it went. Tell me how long it took, good luck . Helix 2 sounds like the best .
Old May 16, 2009 | 12:39 AM
Fishin2Deep4U's Avatar
Look at the Diesel Pros cam. Best spooling cam I ave seen and I am putting one in my truck soon.
And they can do the 12valve lift pump lobe as well, so you can go to the foolproof system if you like.
Dave
Old May 16, 2009 | 11:27 AM
sstockton's Avatar
Dave
Yeah, my helix 2 has that extra lobe as well. Installing it this morning, however the machine shop didn't get my flexplate done this week, so I'm not going to be putting the tranny in or having it running by monday. Hopefully I'll have it going soon though.
Sean
Old May 21, 2009 | 11:05 AM
XLR8R's Avatar
We've had great performance from the Helix 2s... installation is a bit of a pain on both 2nd & 3rd Gens, but we flat-rate them at $600 in the shop.
Old May 21, 2009 | 02:02 PM
The H2 worked better than stock, but cannot compare to the Diesel Pros.
Dave
B.k. Smith
10
Jan 7, 2015 02:29 PM
Oct 31, 2014 08:10 AM
