91 non-ic 4x4 gearvenders overdrive
Old May 13, 2009 | 07:35 PM
estrada5.9's Avatar
Default 91 non-ic 4x4 gearvenders overdrive
91 non-ic 4x4 198000
auto with gear vendors overdrive
bully dog stage two injectors
Full screw not turned up
preboost set to smoke a little more
interior is nice no cracks in dash
No rust
Good sound system
winch bumper no winch
37 inch tires
17 inch wheels
4.88 gears front and rear limited slip in rear
Tranny is aftermarket trying to get the info on it from previous owner
The gear vendor shifts nice uses the high/low beam on the floor to shift it manual the high/low beam is now on the column can be set to auto mode as well
No engine oil drips some seepage but no leaks very strange concept to me leaks let you know there is oil in them right
Straight piped with 6 inch tip
EGTs do not get above 1250 pulled a big hill here on the floor and 1250 was max
16cm exhaust housing
AFE air filter
Yes its tall but with a drop hitch it will pull five horses no prob has seven pin plug
Not so good
tailgate hard to open have to rock it a bit
speedo quit workin right after I got it so 198000 to 200000 or so is more accurate
No tach but thats a first gen thing
leaks a little bit of power steering fluid from steering box
tranny seeps around the pan no drips
rear shock bushings on the axle side are bad so it will clunk a little
Nice rig I am selling because I own four rigs three of which are cummins so I am constantly trying to find something to tinker with or fix on them girlfriend approves but I may be pushing my luck right now my hands are rough anyways and lately they are anyways dirty with oil dirt etc. So I hope this goes to a good home $6000
Last edited by RSWORDS; May 13, 2009 at 07:43 PM. Reason: Just cleaned Up The Pics For You
Old May 14, 2009 | 12:02 AM
need help 6.7's Avatar
love the truck to bad i cant afford it
Old May 15, 2009 | 01:06 AM
estrada5.9's Avatar
5500 obo
Old May 19, 2009 | 09:35 AM
estrada5.9's Avatar
TTT
Old May 19, 2009 | 10:15 AM
biged681985's Avatar
looks pretty clean for a 91. good luck with the sale man.
Old May 19, 2009 | 11:25 AM
estrada5.9's Avatar
Yes sir
Old May 23, 2009 | 06:40 PM
estrada5.9's Avatar
open to offers trades etc.
Old May 26, 2009 | 04:41 PM
estrada5.9's Avatar
TTT same deal offers trades etc
Old May 27, 2009 | 02:27 AM
Chief Engineer's Avatar
Where are you located?
Old May 27, 2009 | 09:49 AM
estrada5.9's Avatar
Northern CA
