Draining the rail?
Old May 12, 2009 | 02:51 PM
Begle1's Avatar
Default Draining the rail?
Can you drain the rail on a Duramax with just programming?
Old May 12, 2009 | 05:27 PM
uwyo_dmax's Avatar
yes with to much pulse width its easy
Old May 12, 2009 | 06:51 PM
Begle1's Avatar
Would any off-the-shelf programmers drain the rail enough to set low-rail-pressure codes?
Old May 12, 2009 | 09:48 PM
uwyo_dmax's Avatar
i would say the PPE hot would definitely do it
Old May 12, 2009 | 10:00 PM
angelic0-'s Avatar
PPE hot set a low rail pressure code in my LLY
at second thought i think it was the edge juice w/ attitude wich did it i can't remember...
it's been a while...
Old May 13, 2009 | 01:53 AM
Supercharged_Duramax's Avatar
Yes
That same calibration could be used if the cp3 components were updated and programmed properly.
Just a thought.
Old May 13, 2009 | 11:22 AM
2500HeavyDuty's Avatar
stacking programmers, clogged fuel filter. PPE tunes. maybe some quadzilla tunes
a p1093 will usually come up if you do
Old May 16, 2009 | 10:30 PM
dozerboy's Avatar
Depends a lot on the truck sometimes 120HP tune can drain the rail.
yzrider250
Diesel Engine Conversions
Aug 10, 2015 11:33 AM
Gitana
Feb 18, 2015 10:08 AM
cfarley0210
Jan 19, 2015 06:00 PM
1988 international
Oct 24, 2014 11:36 PM
growland415
Oct 22, 2014 01:56 PM
