valve guide seal? update on this? Keep them down?
Old May 12, 2009 | 05:06 AM
hereismylife's Avatar
Question valve guide seal? update on this? Keep them down?
I was searching and found that the seal can float up the stem. I am wondering if there is a update for this so this does not happen?
also I came across this..... I wonder if anyone did this?
Valve Stem Oil Seals??? - TDR Roundtable
Old May 12, 2009 | 10:15 AM
94cummins12v's Avatar
ive never herd it happen them seals are on the head lip owfly tight
Old May 12, 2009 | 02:13 PM
I did some searching and found it is kinda common for some to all to lift up the stem. You take the valve cover off and look through the spring and you might see they did lift. I am going to do my springs and want to be prepared before I do it. If I see a this at all I want to be able to update the problem and get it done.
Old May 13, 2009 | 06:56 AM
cummins_guy's Avatar
they way that should only happen is if they were not installed properly.
Old May 13, 2009 | 08:30 PM
i was going to say that. ive never heard of them coming up. you have to push hard to get them on
Old May 15, 2009 | 03:23 PM
Well after searching some more I guess you can use the newer style v s somehow I am still checking .
thanks guys
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
