tranny problems
Old May 11, 2009 | 08:47 PM
94 CuMmInS's Avatar
Default tranny problems
i have a 94 cummins with 82000 on it. boought it to be fixed up. motor is good but my tranny seems iffy. wen i start it and let it sit for 10 15 mins jus so i can move it oout of the way then thing barely moves. i could be at 1500 rmps and the thing barely moves. but if it warms up till i hit the 140 mark on water temp it seems to move alright. idk wut it is? didrty filter maybe oor bad tranny?
Old May 11, 2009 | 09:12 PM
biged681985's Avatar
torque converter bad maybe, im not positive this is your problem, my advice would be call dave goerend up and ask him. or another tranny specialist. jmo
Old May 13, 2009 | 12:35 PM
12valvetater's Avatar
something is plugged up nad not letting fluid move around right. did you check the level of the fluid if the converter is not in oil it will not move dont ask how i know this.
Old May 13, 2009 | 06:39 PM
392hemix's Avatar
sounds like its low on fluid, or posibly a bad converter or weak hydralic pump. Change the fluid and see if it gets any better. I would defenetly pull it anyway, it will need a converter either way if your going to do any mods to it.
Old May 13, 2009 | 06:41 PM
estrada5.9's Avatar
Always best to start with the cheapest fix like low fluid my brother 96 was doin that and he added fluid and it acts way better now
Old May 13, 2009 | 06:52 PM
94 CuMmInS's Avatar
ya i checked fluid it seems to be up there im guessing is converter is shot and ya i prob will end up changing it cuz i will be doing mods in the long run . thanx for the help every1
Old May 13, 2009 | 07:02 PM
392hemix's Avatar
No problem dude good luck
Old May 14, 2009 | 07:00 AM
Diesel Dummie's Avatar
Be sure to check fluid level with tranny in neutral
AHAAN
Jul 19, 2015 10:28 PM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
Ol Goat
Jan 22, 2015 02:16 AM
TNTPrime
Jan 5, 2015 06:13 PM
corey352
94-98 7.3L Performance
Oct 22, 2014 10:58 AM
