EGR butterfly valve
Old May 11, 2009 | 07:26 PM
DslDeamon's Avatar
Default EGR butterfly valve
i already have an EGR delete kit in my truck and been running it that way for awhile but im just wondering if its ok to run the truck with the butterfly valve still their or should it be taken out?
Old May 11, 2009 | 07:36 PM
caveman's Avatar
at a minimum you should unplug it
Old May 11, 2009 | 08:21 PM
DslDeamon's Avatar
the EGR montor?
Old May 12, 2009 | 12:41 AM
funhauler's Avatar
The idea is to un-mount the motor and leave the EGR plugged in. This will make the ECU think that all is well. However, when the EGR opens the air inlet valve closes, at least partially, which will starve your motor for air. It you leave the EGR plugged in and blocked off, you must remove the air inlet butterfly. When I did, my grid heater stays on. I had to unplug it. The grid heater sensor must be near the EGR flow. I did not unmount my EGR motor. I only blocked the Tube form the exhaust to the EGR, and left it plugged in. Good luck.
Old May 12, 2009 | 11:50 PM
DslDeamon's Avatar
i removed the butterfly valve tonight and all went well but when i go to shut off the truck now it shacks more "like an 5.9 would" is this normal with the butterfly valve gone or no??
Old May 13, 2009 | 08:49 PM
funhauler's Avatar
I don't know if this is normal or not. When I removed mine it made no difference when I turn the truck off, or otherwise, except for the grid. Remember, you are modifying your truck from the original manufacturers design and build. This will result in problems / quirks. Try different things. You can always return your truck to the way it was before and see if that was indeed the cause. I am a ways away from a programmer, $$$. I am really hoping to get one so I can see what this bad boy can do with a little more work. Again, good luck.
Old May 21, 2009 | 08:31 PM
CO6.7Cummins's Avatar
Yeah, its normal for it to shake.
The later flashes change how the butterfly valve reacts at idle. So, some of us are forced to remove it or it'll just studder at idle.
RA113024
Mar 13, 2016 07:42 PM
LTreis702
Feb 14, 2015 12:52 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
makuloco2000
Dec 7, 2014 11:15 AM
behrendt1061
Dec 4, 2014 05:49 PM
