pull airdog fuse?
Old May 11, 2009 | 05:26 PM
dhardy1357's Avatar
Default pull airdog fuse?
i was just wandering if when im loading a tune with efi, should i pull my airdog150 fuse so it isnt running while i load a tune? will the pump burn up if the truck isnt running, just turned to the on position
Old May 12, 2009 | 12:07 AM
2500HeavyDuty's Avatar
if the pump turns off when the key is in run pull the fuse out.
i pull mine everytime i flash
Old Jun 8, 2009 | 02:45 PM
DangerousDuramax's Avatar
YES...not only pull the fuse but turn off your stereo and hit your dome switch. This goes for ANY tune your install not just EFI Live tunes. If there is any current draw that spikes it will crash your ECM while installing a tune. Also, your Airdog system is constantly bypassing and returning fuel to the tank. You cant burn it up unless you run out of fuel.
stone9291
Jul 23, 2015 05:13 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
james2562
Nov 2, 2014 08:31 AM
Altonlee
Oct 1, 2014 04:58 PM
