ahhh crap
Old May 11, 2009 | 12:15 AM
TwinStackPete379's Avatar
Default ahhh crap
Well guys I abput got sick the other night. I had the inection pump air lock on me, due to a crappy fuel filter set up on the 97. Might I add was a b***** gettin the air bled out. Had the wife in the truck crankin it over while I purged the return valve on ip. While she was cranking over I noticed I had a dang head stud broke......I almost threw up. I don't have the money for a gasket and studs right now, I'm gettin laid off in a week. I checked it over and its not blown a gasket yet. Its the stud on exhaust manifold side between 3-4 cylinder.. I was thinking tryin to get a left handed drill bit ad get it out then replace it.
Old May 11, 2009 | 12:30 AM
94cummins12v's Avatar
damn thats a run of bad luck. sorry to hear it if you need a spare bolt i got all my stock bolts from when i did studs
Old May 11, 2009 | 12:42 AM
Uncle Bubba's Avatar
Take it to a machine shop to see if they can get the bolt out without havin to pull the head. I don't know how they do the things they do but a good shop sure can do some crazy things.
Old May 11, 2009 | 12:47 AM
ya thats true to. if its easy to get to which my guess it is just drill it then take it out with an easy out shouldnt be a problem
Old May 11, 2009 | 02:23 AM
Thanks guys, I'm gonna try it first with a left handed drill bit. If I can't get it ill have a machine shop do it.
Old May 13, 2009 | 07:14 PM
392hemix's Avatar
Good luck brother, i hate it when you break bolts, sometimes you luck out and get um out easy, sometimes its a lost cause. Let us know how you make out!
Old May 14, 2009 | 07:47 AM
cummins_guy's Avatar
they way i get them out.
go to home depot, get easy outs. go home (before you go home ask yourself do i have a torch of some kind) you will need to heat the stud. read directions on the package and remove.
it really is that easy.
and make sure you get a tap, just remove any deposits left in the block.
hope it helps
Old May 14, 2009 | 01:18 PM
I've used them easy out's a few times. Every damn one of em have snapped off in the hole and made it worse. I know most guys have good luck with em but I never have. The torch will probably be a must have as long as you really know what your doin with it and don't heat things up to much, that could be a mess.
Old May 14, 2009 | 01:27 PM
angelic0-'s Avatar
Am i getting this wrong is it a bolt from the exhaust manifold that vroke or a head bolt that holds the head to the block?
if it's a exhaust manifold bolt it's no biggie.
Old May 14, 2009 | 01:33 PM
K50's Avatar
K50
Head bolt for head to block
