PO299 code
Old May 10, 2009 | 11:02 AM
nightmoves's Avatar
Default PO299 code
I know it is "turbo underboost" but what is the fix and should I be concerned.Truck has 79k 95% trailer towing about 18k gcvw.It has happened about three times while towing usually at a low rpm(truck has 373 gears)so my guess would be the engine is either"lugging" or the turbo is faltering.Thanks in advance.
Jim
Old Jul 12, 2009 | 05:13 PM
Telo's Avatar
6.0's are notorious for failing turbos there is a very good chance if you have your turbo replaced the turbo the code and problem will go away
Old Jul 12, 2009 | 07:49 PM
Superstroker10's Avatar
sounds like the vains in the turbo could be sticking only way to fix that (if thats the case) would be to change the turbo.
also when it under boosts do you loose power and have excessive smoke (black)
Old Jul 17, 2009 | 10:46 PM
Big Angry Hillbilly's Avatar
Replacement of the turbo is not necessary.
Take the turbo halves apart and clean the carbon and crap off the unison ring and CHRA. If they are pitted/rusted or the actuator hole is oblonged - CHRA and unison ring should be replaced.
Old Aug 8, 2009 | 01:34 AM
MONSTERPLOW's Avatar
Just had mine replaced along with a larger drain tube .
she was blowing oil down the pipe resulting in "white smoke "
Old Aug 8, 2009 | 10:50 PM
That larger drain tube is a big crock of ****.
I ordered a complete reman (Turbo to oil pan) 6.0, and it came with the small (old style) drain tube installed.
I personally don't think it does squat, but I put 'em on if they've got the little tube and I'm workin on 'em.
Old Sep 6, 2009 | 10:04 PM
seriously , I got the turbo douched and swapped out the drain tube .....no more oil running down pipe and the white smoke dissapeared
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
