ANYONE SELLING 200-250HP INJECTOR TIPS
Old May 10, 2009 | 08:31 AM
RIGGLE21's Avatar
Default ANYONE SELLING 200-250HP INJECTOR TIPS
INJECTOR TIPS WANTED
Old May 10, 2009 | 02:46 PM
We might be about to get some 200hp Tips. Do you have the Mods to support an injector of this size?
Luke
Old May 10, 2009 | 08:45 PM
RIGGLE21's Avatar
I WILL DO WHAT I HAVE TO DO AFTER INSTULATION? THINKING OF HX50 TWINNED WITH HX35 OR HX35/HX55 NOT SURE YET NEED MORE FUEL TO TEST
Old May 11, 2009 | 04:33 AM
VP44 Truck or a Common Rail?
Old May 11, 2009 | 06:54 AM
RIGGLE21's Avatar
VP44 somehow I posted this in the CR section! Got in a hurry I guess
Old May 11, 2009 | 06:50 PM
graygoblin's Avatar
ur gonna need alot of turbo for that plus somthin for fuel pressure
Old May 11, 2009 | 07:42 PM
connermcpherson's Avatar
no offense dude but that twin setup is junk over junk
Old May 11, 2009 | 08:31 PM
sstockton's Avatar
They actually aren't as bad as you'd think, if you wastegate it right and run the right housings. Is it the best twins set out there? Not even close. However, spec on the Hx50 is similar to the H2E I'm running now below a hx35, and with smaller sticks it works great. The truck will run mid 12's without breaking 1100* and 50psi boost. Granted I have a 38mm external gate and a 25cm housing on the H2E. As a single, they are pretty weak, because the higher you push the PR the less Volume you flow, but when compounded and running a decent PR around 2.0-3.0:1 they move a fair amount, and you become restricted by the top turbo. With all that said, I'm going to a 62/65/14-s480 combo.
Back to the original poster. I have a set of brand new 200hp tips installed on bodies if you are interested PM me. I can also have them pop tested as well, I just never got around to it.
Sean
Old May 17, 2009 | 06:19 PM
jackblack99's Avatar
ive got a set of 7x .014 240hp injectors with less than 500 miles on em. pm me if interested
Dec 15, 2014 03:00 AM
