Well I finally bought/installed the Adrenaline w/ Pulse, but have a few questions...
Old May 10, 2009 | 07:32 AM
HotRodCrewCab's Avatar
Default Well I finally bought/installed the Adrenaline w/ Pulse, but have a few questions...
I just bought the Adrenaline last wednesday and installed it. Everything works great, no complaints and the ability to custom tune is awesome . Now the questions:
1) I have read on a few other posts that people are hitting 30-40 psi on the factory tunes, but I have watched, and went into the data logging and the highest ive hit is 22. Normal?
2) I downloaded the adr300g tune, and followed the directions (believe it or not), but nothing seemed to change when I put it back in the truck. I went to the Load Tune part, and loaded Tune 1, which I had not seen before, and as soon as I started to release the clutch, it started surging and poping. I looked at the parameters and nothing made sense.
Power levels = 1
timing scale = 0
everything else = 0
boost scale = 40
Old May 10, 2009 | 02:44 PM
You will need to upload a tune custom tune it and then save it to Tune #1 or Tune #2. Out of the Box there is nothing saved to Tune#1 or #2. For instance download ADRCOMP3 go into custom tuning and save it to Tune#1. Then download ADRTQ and save it as Tune #2. Then Download ADR2000. Now The ADRCOMP will be on Tune#1, ADRTQ will be on Tune#2 and the Factory Tune will be ADR2000. Make Since?
Old May 10, 2009 | 04:24 PM
Ill have to give it a try... there really arent any instructions on how to download new tunes... I figured someone on here had figured it out, thanks a lot.
Old May 10, 2009 | 07:57 PM
If you have any problems give me a Call.
Old May 10, 2009 | 08:27 PM
Yeah, I tried your instructions this evening, worked like a charm went out for a test ride and the clutch broke loose in 4th with the comp tune on 5 so im gonna have to take it easy for a few weeks till i figure out what clutch I want
Old May 11, 2009 | 02:23 PM
oklahoma_6speed's Avatar
SOUTH BEND DD CLUTCH. ALL THE WAY....3600..
Old May 11, 2009 | 02:52 PM
Valair DD.
No Sled Pulling get the Valair Nodular DD 3250# or 3400# ( Non-SFI Approved )
Sled Pulling get Valair DD 3650# ( SFI Approved )
Old May 11, 2009 | 06:54 PM
01quadcab's Avatar
south bend
