replacing the t stats
Old May 9, 2009 | 03:25 PM
SnoMan's Avatar
Default replacing the t stats
Guys I hate to sound like a dumba$$ here but I don't want anything unexpected come up. How do you replace the thermostats on the engine. Do you just take off the long tstat housing and is there 2 tstats there in series or is it some other way. My truck only runs at about 170degrees at about 70degrees outside and on a long trip only gets to 180 the book says it should run 200degrees. So I think the tstat is stuck open.
Old May 9, 2009 | 03:38 PM
DangerousDuramax's Avatar
Yep you got it. The housing is a one piece unit that houses both T stats.
Old May 9, 2009 | 04:52 PM
2500HeavyDuty's Avatar
the big old long steel tube and housing that got 4 bolts on it, you cn duscooect the rad hose and pull them 4 bolts and lay the tstat housing out the way
Old May 10, 2009 | 06:21 AM
SnoMan's Avatar
What temps are your guys truck running mine is only 170 on short runs. Does that sound low? Thanks
Old May 16, 2009 | 10:48 PM
dozerboy's Avatar
Not really for 70* if you had one stuck open it would take more then a short run to get it up to 170*.
chris_fininzio
Jan 7, 2015 03:19 PM
Gizmo52
Jan 6, 2015 11:58 AM
woodsman27
Dec 9, 2014 09:55 AM
abuchanan250
Oct 6, 2014 09:56 PM
