Problems with 01
Old May 8, 2009 | 06:46 AM
JLWelding's Avatar
Default Problems with 01
This has been going on for a while now ,thought I could fix it but. Here goes eng. is slugesh when shifting gears rpm drop like a rock,before you can shift from 3rd to 4th it has fallen all the way to idle.When coming to red light you kick it in neutral, rpm will fall below 600 then surge up and down a couple times if you have A/C on it will almost die. Put new APPS on yesterday no help, had eng. scanded and it says the cam sensor is not working so replaced, still says not working. Unpluged the Edge Ez and no help. Vp is about 2 years old and been running two stroke.
Old May 8, 2009 | 07:14 AM
CumminsKid6's Avatar
it could just be ur vp is taking a crap. but did after u fixed the cam position sensor it said it still wasnt working? if so one of the wires in between could be broke or cracked and grounding somehow not give it the proper reading
Old May 8, 2009 | 07:00 PM
JLWelding's Avatar
Wire is ok the best I can tell. Ran a continuety test and it is making a loop. I have spent so much time on this I am about to throw a VP44 at it.
Old May 8, 2009 | 10:41 PM
well best of luck. to ya. thats really all i could think be wrong with it
Old May 9, 2009 | 01:51 PM
01quadcab's Avatar
just ppump it and not have to worry anymore
Old May 9, 2009 | 02:02 PM
JLWelding's Avatar
You got that right,I wish I had the money. There's a guy with a 01 and It looks tough.
Old May 10, 2009 | 01:49 AM
01quadcab's Avatar
I have seen a few. an 01 make 1000 on fuel and a 02 done up ppumps. If my vp dies it's going bye bye and hello ppump
Old May 10, 2009 | 09:21 AM
torquey's Avatar
any show and tell on p-pumpin an 01?
Old May 14, 2009 | 11:09 AM
cummins_guy's Avatar
they have converter kits for them, Ill see if i can get some pics.
Old May 14, 2009 | 11:44 AM
Mr.Krabs's Avatar
Word,next time I change out a VP it will be with a P7100
