Head work?
Old May 7, 2009 | 01:52 PM
rallyit67's Avatar
Default Head work?
What kinda head work needs to be done to handle 65psi? Will just studs do it or do I need more?
I've heard of just going and re-tightening your stock studs and you can handle a bit more, does anyone know about how much the head can handle with just re-tightening stock studs?
Old May 7, 2009 | 03:01 PM
12valvetater's Avatar
o-rings on the head will handle 65psi with a stock gasket and studs but thats about the limit im having the block and head o-ringed.
Old May 7, 2009 | 03:14 PM
rallyit67's Avatar
so o-ring the head and stock studs? or aftermarket studs?
Old May 7, 2009 | 05:10 PM
Cummins97's Avatar
Stock, they are "bolts" not studs.
Old May 7, 2009 | 05:34 PM
rallyit67's Avatar
whats a ball park figure on how much it will cost to get it o-ringed
Old May 7, 2009 | 10:28 PM
392hemix's Avatar
I am more concerned on who will do it. No one in nh does that stuff.
Old May 8, 2009 | 12:08 AM
94cummins12v's Avatar
i got my head o-ringed for $250. i have o-ringed and ported/polished head and am running 12mm arp studs with a .020 over marine gasket
Old May 8, 2009 | 12:18 AM
angelic0-'s Avatar
how many PSI should one expect to have when running around 400rwhp
Old May 8, 2009 | 12:28 AM
dont mater about psi it depends on the size of the turbo. you can have the stock turbo at 30-35psi making 400hp or you can have a aftermarket big turbo making 20-25psi paking 400hp it all depends on what you got for modifications
Old May 10, 2009 | 10:36 PM
rallyit67's Avatar
if im going to o ring it and have studs should i just be putting back on a stock thickness gasket or something a little thicker? is there a benefit for using a thicker gasket or different gasket then stock?
