vw site
Old May 7, 2009 | 10:27 AM
jhase's Avatar
Default vw site
does anyone know the site were i can find the shut off solenoid it vw somethin
Old May 7, 2009 | 12:51 PM
RSWORDS's Avatar
www.dieselvw.com has them for $10 + $4 shipping.
They are not that bad to change, remove the bracket for the throttle assembly. Remove the bracket that holds the ve or trim about 3/4" off and you can get to it pretty easy with a wrench.
Old May 7, 2009 | 02:18 PM
peobryant's Avatar
I would hold off on installing that until you get bigger injectors. No need blowing another one, andhaving to spend the $15 again.
Just my opinion.
Old May 7, 2009 | 03:20 PM
RSWORDS's Avatar
Just my opinion.
unless you want to shut off your truck. I have about all the fuel you can ask for from a stockish 12mm VE and have not had any issues with the shut down solinoid.
Your other option is to gut it and install a pull cable to shut down the truck.
Old May 7, 2009 | 03:40 PM
peobryant's Avatar
You have a Non Intercooled truck, correct? Those stock 4X.012's are huge compared to our 6X.009's, which is why it is more of a problem with the intercooled trucks.
I have seen it happen on Non I/C trucks as well though.
Old May 7, 2009 | 03:54 PM
RSWORDS's Avatar
It is definatly a problem with both and yes the I/c'ed more but not enough of a problem that it would cause me to drop $300-$700 on a set of injectors. Seen plenty of I/C and non-I/C that go for a good time w/o problems.
Old May 7, 2009 | 04:04 PM
peobryant's Avatar
I thought I read somewhere that he was looking to get a new set of injectors, that is why I suggested waiting. I may have read wrong though.
I would personally continue to shut the truck off with the lever on the pump, until I got new injectors, or turned the pump down, but I guess I'm cheap.
The guy I got my running boards from said his solenoid lasted 3 days after he cranked his pump.
Old May 7, 2009 | 04:30 PM
RSWORDS's Avatar
I would not mind using the lever to shut down the truck... Till the fist time it was raining is *** off. then you would have to put a pull cable in the cab.
I would not be surprised by a original half worn out soliniod giving up right after the pump was cranked.
When you take the pluner out take a good look at it and make sure there are no rough edges on it. Grind the tip flat and then put a smooth radius on the edge. The lip on the stock tip hangs out in the fuel passage and gets torn up during high fuel flow.
Bosshog06
Mar 18, 2016 10:50 AM
HardLuck
Mar 10, 2016 03:33 AM
Silver-raid-o
Mar 4, 2015 02:00 PM
PopRay
Nov 30, 2014 11:05 PM
plow_this
Nov 16, 2014 11:40 PM
