Installing boost gauge
Old May 6, 2009 | 11:11 PM
cummins17's Avatar
Default Installing boost gauge
Which way does everyone install their boost gauge? Do you drill and tap the intake manifold or just use a T fitting off the pressure line from the turbo?
Old May 6, 2009 | 11:35 PM
coyropin's Avatar
You can drill and tap the intake which i did or there is a plug number 26
sorry dr evil i stole you pic from the other post
Old May 6, 2009 | 11:42 PM
cummins17's Avatar
what exactly is that plug to start with?
Old May 7, 2009 | 01:31 AM
coyropin's Avatar
that just goes in your intake housing, your intake temp sender is # 7 so it will be right next to it.
Old May 7, 2009 | 02:15 AM
Fishin2Deep4U's Avatar
The easiest way is to use a boost bolt.
However, I prefer to drill and tap the intake. The gauge will live MUCH longer.
Dave
Old May 7, 2009 | 07:02 AM
cummins17's Avatar
where at should i tap the manifold?
Old May 7, 2009 | 11:52 AM
The pic isnt the best but you will be able to see the fitting:
Old May 7, 2009 | 11:53 AM
Glad you did
Old May 7, 2009 | 12:30 PM
dukeboy_318's Avatar
mine is installed in the plug in the diagram above, works great, been on there for over 100k not had a problem
Devon7.3
Sep 22, 2015 07:59 AM
Big-j
Sep 20, 2015 11:31 AM
chen
May 29, 2015 04:34 AM
ash23k
Dec 30, 2014 08:31 PM
mt_wi86
Oct 7, 2014 01:13 AM
