Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Video's from the weekend○
Old Jun 11, 2007 | 04:15 PM
cummin_un_glued's Avatar
FormerVendor
You Tube Video's from the weekend○
those were the first hooks on the new clutch in the order that they happened....the track ar brians sucked really bad it was wayyyy too loose, but now i need to build block, traction bars, and a weight rack
Old Jun 11, 2007 | 04:55 PM
06 DIESEL's Avatar
:pc: Looks good, time for some more mods?
Old Jun 11, 2007 | 05:27 PM
FormerVendor
yeah fuel system, fuel gauges, and hot code for the juice are next
Old Jun 11, 2007 | 07:37 PM
DazedandConfused's Avatar
Last hook seemed to be the best.
Andy
Old Jun 11, 2007 | 08:15 PM
FormerVendor
yeah andy by far the best hook, i done everything the same the only difference was the different track. at the brians truck shop pull they didnt scrape away the loose dirt so as soon as i let off the clutch even half way it started spinning, just couldnt get the power to the ground. but as you seen when it gets to the ground it works pretty good, i just need to build a weight rack and get some tractor weights. i was allmost 1000lbs under weight for the class i was pulling in.
Old Jun 11, 2007 | 08:35 PM
Yeah you can tell that one track was very loose. Just keep up the good work and keep the vids coming.
Andy
Old Jun 11, 2007 | 09:58 PM
sawyer45306's Avatar
Looks good
Old Jun 11, 2007 | 10:01 PM
MRaynor's Avatar
Good going.
Old Jun 11, 2007 | 11:18 PM
FormerVendor
the first 3 videos were all at the brians truck shop pull in lead hill AR and the last video was at the rogersville FFA pull in rogersville MO
will do i've got at least 3 more pulls and maybe 4 this summer so i will have more videos to come for sure.
i'm going to try to get some blocks and traction bars built this summer and then try to find the tractor weights this winter to use next year
Jul 6, 2015 12:00 PM
