TRANSFERCASE
Old May 6, 2009 | 08:56 PM
wt_offroad's Avatar
Default TRANSFERCASE
99' Dodge, Auto, 4x4, What oil should be in the transfer case? Going to change it out in about an hour and want to know what it takes. 50w, 80/90, 75/90? thanks
Old May 6, 2009 | 09:06 PM
Paco98's Avatar
ATF-4 is what I just put in mine and I called the dealership to find out
Old May 6, 2009 | 09:07 PM
FastCR's Avatar
yeah the manual probably says ATF, although if your trans is sealed off from the T case, gear oil will keep it cooler. hold on I'll call my grandpa and ask what weight if you want to go that route.
Old May 6, 2009 | 09:16 PM
yj junker's Avatar
atf only
Old May 6, 2009 | 10:59 PM
wt_offroad's Avatar
ATF IT IS THANKS.
Old May 6, 2009 | 11:03 PM
94cummins12v's Avatar
ATF+4 is the stuff to use.
Old May 7, 2009 | 12:12 AM
It will be fine with ATF+3 - ATF+4 is spendy and you dont need it.
http://www.dodgeram.org/tech/specs/tranfer_case.htm
Old May 7, 2009 | 01:52 AM
Fishin2Deep4U's Avatar
Yep, ATF will work fine, even the cheap stuff (DEX/ MERC).
Dave
Old May 7, 2009 | 10:14 AM
DslDeamon's Avatar
I used ATF+3 in my last truck and i put over 90,000 on it so i would go with that
Old May 7, 2009 | 12:36 PM
dukeboy_318's Avatar
me too, ATF+3 all the way
RedChevy44
Apr 21, 2015 05:47 AM
