not shifting right
Old May 5, 2009 | 03:51 PM
cumminskid92's Avatar
Default not shifting right
since i had my tranny rebuilt it has not shifted right from 2nd to 3rd. if i am running it hard it never seems to want to shift. if i let out of the throttle it will shift fine or if i just drive responsible... ha right. also if i let out and coast for more than a few seconds it will down shift out of overdrive. it did that before i had the tranny rebuilt too. i didnt know if there were any adjustment and if there are what are the suppose to be set at.
Old May 5, 2009 | 04:26 PM
RSWORDS's Avatar
Try setting your kick-down/TV cable what ever you want to call it. I'll find teh procedure here in a second
Old May 5, 2009 | 04:27 PM
RSWORDS's Avatar
Here give this a ahot and let us know.
https://www.dieselbombers.com/1st-ge...djustment.html
Old May 5, 2009 | 04:33 PM
alright ill give it a shot. thanks
Old May 5, 2009 | 04:39 PM
remps's Avatar
Is your kick down linkage set right?It doesn't sound like a linkage problem,but I would check it out anyway.On my truck the kickdown cable is mounted to the throttle bracket,and there is a locking clip that lets you slide the cable to the right position.It was touchy on my truck to get it to shift like I wanted.Factory setting for mine is .225 inch from the back of the slot pin to the back of the slot,but I ended up with .26 to make it shift sooner due to pump mods.Probably a thread somewhere pertaining to your truck.
Old May 5, 2009 | 05:13 PM
well i adjusted it and it definately fixed the problem with it not wanting to shift from 2nd to 3rd but it still wants to down shift from overdrive when i let out on the trottle. it doesnt matter how fast i am going, i can be running 90 and it will still do it.
Old May 5, 2009 | 06:51 PM
bigrich's Avatar
sounds like a tps problem
Old May 5, 2009 | 06:54 PM
RSWORDS's Avatar
could be a tps problem.. Hold On Another second...
Old May 5, 2009 | 07:04 PM
RSWORDS's Avatar
Read here
https://www.dieselbombers.com/1st-ge...tml#post333961
Old May 5, 2009 | 09:13 PM
thanks i will check it out and get back with you.
alright before i start adjusting it do i need to increase or decrease the voltage if it is downshifting too soon
Last edited by cumminskid92; May 5, 2009 at 09:13 PM. Reason: Automerged Doublepost
