Diesel tune up (sevice)
Old May 4, 2009 | 02:04 PM
4x4_druid's Avatar
Default Diesel tune up (sevice)
Hi All,
New to diesels and I have an '03 Ram cummins. For all my gas vehicles normally I would do a spring "tune up" plugs/wires/oil an filter ect... What do you all normally do to maintain/tune up your cummins??
I was thinking oil and filter change and new fuel filter is there anything else that should be taken care of on a regular bases on the cummins??
Thanks
Old May 4, 2009 | 03:06 PM
Change Oil and Filter, Change Fuel Filter, Clean IAT and MAP Sensors, Check all your other fluids such as Transfer Case, Front and Rear Diffs, Check Brakes including Parking Brake.
Old May 5, 2009 | 09:00 PM
Stacked03's Avatar
yeah what he said!! LOL
Old May 6, 2009 | 07:36 AM
elephantrider's Avatar
speaking of maintenance / tune ups, is there a " kit "
that allows you to remove the diff fluids and replace
it ? like a pump of some sort ?
Old May 6, 2009 | 12:26 PM
4x4_druid's Avatar
Hey thanks for the heads up. Do you know if there is a write up showing where the IAT and MAP sensors are located on an '03 cummins??
cheers
You are better off taking the cover off completely so you can inspect the gears for any damage....
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
tbreddiesel
Contests And Give Aways
Jul 21, 2015 07:28 AM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
