will not start
Old May 4, 2009 | 10:17 AM
onlydiesel88's Avatar
Default will not start
i have a 03 6.0 it started fine last night. this morning it will crank but will not start. it is not a smooth crank it sounds like it wants to start but it just wont help
Old May 4, 2009 | 11:44 AM
Dieselhead Jake's Avatar
i had the same problem....how old are your batteries?
Old May 4, 2009 | 01:30 PM
not that old and it cranks good
Old May 8, 2009 | 03:52 PM
DslDeamon's Avatar
I use to have an 03 f250 powerstroke with the same problem it turned out to be a bad gasket in the fuel filter on the fram and it was sucking air to the point where i wouldnt start/run i hope this will help
Old May 9, 2009 | 01:32 AM
YMMOT's Avatar
If it isn't the filter it could be the ICP Sensor. A Powerstroke needs to see 500PSI at the high pressure oil rail to start. Could also be a crank postion sensor.
Old May 9, 2009 | 03:54 AM
angelic0-'s Avatar
Try bleeding air, it might have sucked air if any seals are bad?
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
