191 delivery valves?
Old May 2, 2009 | 11:26 PM
bowtech's Avatar
Default 191 delivery valves?
for the p7100 pump. they woth gettin? wat they do? wat are the pros and cons to them?
Old May 3, 2009 | 01:22 AM
94cummins12v's Avatar
they add more fuel to the fire. i wouldnt recomend them if you dont have bigger injectors, timing, fuel plate or turbo. even for the mods i have there a tad more fuel than i need, even with your injectors and stock turbo i dont recomend them
Old May 3, 2009 | 10:13 AM
94 12valve's Avatar
look into a set of 181's
Old May 3, 2009 | 12:34 PM
i was going to mention that aswell the 181's would be a bit better for your truck and alot less fuel then the 191's
Old May 3, 2009 | 02:47 PM
bowtech's Avatar
ok thakns. wat are the stock ones?
Old May 3, 2009 | 05:37 PM
i dont remember what size our 94's have in them
Old May 3, 2009 | 06:18 PM
bowtech's Avatar
so the 181s will they help it running smoother or wat? wat are the pros and cons? like the egt goin up. hard on tranni? all that
Old May 3, 2009 | 07:23 PM
well they will deliver more fuel than you stock ones will. yes you will have a gain in EGTs but not near as bad as the 191's do. you will notice a bit of power gain, yes it is hard on the trany but any aftermarket upgrade is, i forgot do you have a auto or 5speed
Old May 3, 2009 | 09:33 PM
bowtech's Avatar
have a auto just had the tranni rebuilt but not beefed up so im lookin to ats or a beefed up tranni and converter when the times come. you no any good ones that would be cheaper than ats or somethin?
Old May 3, 2009 | 11:37 PM
dont ever run an ATS they dont stand behind there products. the local shop here just disowned them because of it. search the forums i have a 5speed, you need any info on that you look me up but on an auto im a bit rusty for info
