Blown head gasket???
Old May 2, 2009 | 08:24 PM
Lil Red Express's Avatar
Default Blown head gasket???
My 02 with only 76000+ on the clock keeps pressurizing the cooling system and blowing coolant out of the over flow. Changed the rad cap but it still blows out. no oil in coolant or coolant in oil. Not low on power, fuel mileage is normal, does not get hot. Only 34lbs of boost, but my exhaust temps can hit 1500 real quick.
NO ideas??????
Last edited by Lil Red Express; May 2, 2009 at 08:24 PM. Reason: Automerged Doublepost
Old May 2, 2009 | 08:44 PM
Tweaker727's Avatar
Do a " Block test " from napa, it's some little plastic tub with water in it that will change color if hydrocarbons are detected.
Sounds to me like water pump issue or a improper burping of the cooling system,
Try changing the thermostat and flushing the system while your doing all of that,
I've never heard of a headgasket issue on these 5.9's esp. with only 76k miles on it,
Let us know !
Old May 3, 2009 | 01:03 AM
Your probably just Boiling the Coolant. I'd keep an eye on the Coolant Temps and my EGTS.
Old May 3, 2009 | 01:42 AM
94cummins12v's Avatar
ya watch your water temp if it seems like its hotter than usual it could be athermostat issue. as far as headgasket problem it could be as well when mine was leaking the 3rd time it was just the lightest leak into the overflow bottle that you could faintly hear and sure enough
Let us know !
you have never herd of a headgasket issue on a 5.9l before? hell im on my 4th headgasket sence ive owned the truck. they blow easily on these trucks especially with an aftermarket turbo. them stock gaskets are only rated at 45psi and the older they are the less psi they can take
Last edited by 94cummins12v; May 3, 2009 at 01:42 AM. Reason: Automerged Doublepost
Old May 3, 2009 | 09:35 AM
Tweaker727's Avatar
I meant under stock conditions, and he said he only had 76,000 miles on it,
But true, me being new to the diesel world i have not heard of many of them having issues, but hey. i'm still learning'
Old May 3, 2009 | 06:07 PM
Look at my sig an you will see its not stock.
I did however find the leak this am. Its at the very front of the head. Oh well guess I get to do a head gasket this next weekend. Anyone need something to do this weekend
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
Diesel Addict
Price Quote - Request A Price
Dec 10, 2014 06:52 PM
turbodiesel123
6.2L & 6.5L Performance
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
1994cummims
9
Oct 15, 2014 11:37 AM
