EGR blocker plates
Old May 2, 2009 | 03:02 PM
DslDeamon's Avatar
Default EGR blocker plates
I was talking to my buddy today and he wants to do an egr delete to his truck now that he has all the bugs worked out of his dpf delete and i do alot of metal working as well. now heres my question he asked me if i could make him up some egr blocker plates for his truck but my concern is all i have is steel and iron plating would that be ok to use or should he just go and buy the blocker plates like i did?
Old May 2, 2009 | 03:04 PM
warlock06's Avatar
youll be fine , just use the gaskets as the templates. and you should use 3/8 at least on the intake side, i have seem the flex and loose boost pressure.
Old May 3, 2009 | 03:20 AM
ETXBlueRam's Avatar
Steel will be fine as long as you make sure the gasket side of the plate is good and flat. Keep your surface finish on the gasket side no smoother than about 250. That way it will get a good bite on the gasket and be less likely to leak. A fairly uniform pattern from a 60 grit grinding disc will do the trick. As was mentioned before, the gasket makes a good template if that's all you have available.
Old May 3, 2009 | 07:35 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i bought mine too like you did but have took it off and traced it on paper and faxed it for guys. steel will be fine. thanks tony at mightydiesel.com 1 877 354 7008 for your needs
Old May 3, 2009 | 01:10 PM
DslDeamon's Avatar
ok thank you guys
Old May 5, 2009 | 07:46 AM
MRowsh's Avatar
Go to AGRI Supply or a Farm supply place and get yourself some heavy duty washers with the same diameter. Then weld it shut. That is what I did and it works great. I do a lot of metal work to include black smithing too.
This was the fastest and cheapest way to get something perfectly fiting the existing clamps at each end of EGR pipe.
Old May 5, 2009 | 03:09 PM
DslDeamon's Avatar
thanks guys.....would he have to unplug anything? or just leave everything alone he has no programmer yet like on mine im running a power pup for right now.
Old May 6, 2009 | 07:31 AM
MRowsh's Avatar
I recommend that he should not do anything till he get a Smarty or whatever lese and then do all the mods all together at the same time. (EGR and DPF delete, and then use Smarty version ME to take care of the regen issues).
I went through painfull way of removing EGR first and then others one at the time because Smarty was not available.
Now that there is a Smarty for 6.7L engines, then he should do it the right way!
syctaz
Jun 26, 2015 12:20 PM
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
dscp
Apr 17, 2015 02:51 PM
Bighouse
Apr 9, 2015 06:51 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
