6.0 blowing white smoke....HELP.......
Old May 2, 2009 | 01:33 PM
smcguire's Avatar
Default 6.0 blowing white smoke....HELP.......
What would case 05 6.0 to blow white smoke after warm up,puke black crap out of muffler,run a little warm. EGR Cooler?
Old May 2, 2009 | 01:35 PM
chevycummins1@yahoo.com's Avatar
how many miles are on your truck, have you checked your antifreeze lately?? could be a head gasket or the egr cooler.
Old May 3, 2009 | 01:00 PM
MONSTERPLOW's Avatar
I believe it s the refinery changing out the winter blend . Happens every year this time .
Old May 3, 2009 | 01:06 PM
are you in pa ,nj or md. the refineries are switching over from winter blend .mine smokes every year about this time . does is just blow a small cloud from each stop ?
try tickling the skinny pedal on the turnpike for about an hour . blow it out . do you IDLE alot ? there are a lot of posiblities to consider.
Old May 3, 2009 | 02:01 PM
bobcat67's Avatar
mine never blows white smoke and i'm 100% sure they've been changing out from the winter blend but I drive a cummins so i don't know if powerstrokes would do that or not i'm assuming they shouldn't but who knows
Old May 3, 2009 | 02:03 PM
dieseldude03's Avatar
White smoke a lot of time means a head gasket went south, though it can also point to a bad injector. The "black crap" very well could be soot carried out of the exhaust by water/coolant/steam from coolant leaking into the combustion chamber. I'm sure someone more familiar with the PSD will be able to confirm or deny that though. Good luck.
Old May 3, 2009 | 10:20 PM
BLACK_06POWERSTROKE's Avatar
how many miles.. have you pulled your egr valve to look at it,,, is there a bunch of white stuff on your degas bottle..
Old May 4, 2009 | 10:51 AM
twinpeaksdiesel's Avatar
First of all does this truck smoke white all of the time or just at start up? If is smokes all of the time it could be the egr cooler, many problems with these I'm sure you've heard. One way to tell is to pull out your EGR valve and see if it has a black sludge on it. If you go to buy a cooler, make sure the stamping number has a c6 in it. The earlier coolers, c5 c4 had very small coolant passages that led to this issue. The last one that I got from Ford still was the old number, just a heads up. If it was me I would simply do a EGR delete, it cost about the same in the end and is much more benificial. The problem with this is emissions restrictions depending on where you live. Good luck to ya and if you have further question please ask.
Old Aug 8, 2009 | 01:44 AM
them turbos have notorious chra sticking and small oil drain line . the dealer specifically carries a kit for it .
Is there oil running down your exaust pipe from the turbo ???
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
mihilo
Sep 16, 2015 10:42 AM
zoomer10h
Feb 6, 2015 01:38 AM
