turning the pump up
Old May 1, 2009 | 11:02 AM
jbonnewell's Avatar
Default turning the pump up
I'm not sure where/ how to turn up the fuel pump on my 1st gen cummins. if i could see some pics that would be very helpful or a website link. really any advice would be helpful, thanks
Old May 1, 2009 | 02:15 PM
RSWORDS's Avatar
Here you go! Real good read!
Turning up the pre 94 Ram diesel injector pump
Old May 1, 2009 | 02:28 PM
jbonnewell's Avatar
awesome thank you, this is awesome, i'm jacked thanks man
Old Jun 27, 2009 | 11:04 AM
sootman's Avatar
is there more clear instructions with real-life pics out there?
Old Jun 27, 2009 | 02:42 PM
RSWORDS's Avatar
If you go look at it its really pretty simple. Here is a little deal Logan made.
https://www.dieselbombers.com/1st-ge...-pump-you.html
Old Aug 24, 2009 | 10:32 PM
TTipsword's Avatar
the is some video on youtube about it. cant remember quite what its called though.
Old Aug 24, 2009 | 11:03 PM
tower_ofpower's Avatar
was it pump tuning or timing advance? there is the timing advance one... it's a good watch.
Old Jan 5, 2010 | 09:49 PM
jasonfriedlin's Avatar
https://www.dieselbombers.com/5-9l-r...g-pump-up.html
Old Jan 7, 2011 | 08:59 AM
1stgen350's Avatar
Default ve44 pump
testmasters in savanna ga can do about anything to it ,but the toid me that its more work than is needed i have a 93 d350 daully with4in turbo back no mur power pin turned all the way in m@h m5 fuel pin 3200 spring and the timing has been moved 1/8 inch ATS said that i should be around 300 to 350 at the wheels
Old Apr 23, 2013 | 01:07 AM
southernabcumminsguy's Avatar
anyone know the part number for the governor 366 spring ?
