more take off power?
Old May 1, 2009 | 06:22 AM
BAD ASS RAM's Avatar
Default more take off power?
i got a question,how do i make my truc khave more of a holeshot?it is stout as hell when the smoke clears!it's like it needs more air,i know i can do the turbo thing,but money's tight.what about an intake manifold,any suggestions? thanks.
Old May 1, 2009 | 09:10 AM
94 12valve's Avatar
the easy way to get more air is to slide the plate back
Old May 1, 2009 | 09:29 AM
what plate?the fuel plate?i thought that only controlled fuel.
Old May 1, 2009 | 11:00 AM
rkadcock's Avatar
N.M. Bombers Director
Yah but giving the truck less fuel gives it a chance to get some more air into the system and allows it to breathe a little more
94 12valve's Avatar
yes the fuel plate, less fuel means more air
Old May 1, 2009 | 11:07 AM
WHAT WOULD BE THE EASIEST AND LESS EXPENSIVE WAY TO GET MORE AIR WITH THE FUEL I'M GETTING NOW WITH THE PLATE LIKE I HAVE IT?AND DO YOU THINK THAT IS WHY I'M A LITTLE SLUGGISH OF THE START?
Old May 1, 2009 | 11:11 AM
94 12valve's Avatar
I think you have way to much fuel down low when you launch is there clouds of smoke?
Old May 1, 2009 | 11:16 AM
94cummins12v's Avatar
get an hx35/40 hybrid turbo with a 16cm housing there good for 550hp and there all the air you will need with mild mods, and there way less expensive than a performance turbo
Old May 1, 2009 | 11:24 AM
94 12valve's Avatar
thats gonna be a hot and short 550rwhp run on that little 35/40
Old May 1, 2009 | 11:27 AM
YEAH PRETTY GOOD SMOKE.I WORK AT A MACHINE SHOP.IF I CAN GET A HX40 COMPRESSOR WHEEL,TO MAKE A HYBRID DO I JUST HAVE TO PUT THE WHEEL IN MY HOUSING?
