SCIV
Old Apr 29, 2009 | 05:20 PM
dhardy1357's Avatar
Default SCIV
i just got my truck back from gettin the SCIV installed. everything seems ok except the trans temp was hitting 200+. i have never seen it above 180 until today. it was about 80 degrees today. is this anything to worry about?
Old Apr 29, 2009 | 11:24 PM
2500HeavyDuty's Avatar
the SCIV runs hotter than stock.
Old Apr 30, 2009 | 03:57 PM
K50's Avatar
K50
wow... why so hot Danny?
Old Apr 30, 2009 | 06:50 PM
dhardy1357's Avatar
something bad happened today. driving home from work, got on it a little bit and went into limp mode with the SCIV. it threw a P1721( trim solenoid "b" controlled clutch not engaged). the tranny temp was up to almost 250. anyone got any info on this would very much appreciated. just spent my last dollar on a new tranny and its messin up. not good
Old May 1, 2009 | 12:09 AM
take it back to where you got it built at, something is not right.
its running way to hot, could be clogged filters or worse, change the spin on filter and make sure u swap the onto the new one. and cut open the old one to see of its dirty.
or take it back to where you got it built at and let them deal with it.
Old May 2, 2009 | 06:01 PM
scramHD's Avatar
solenoid sticking.
Could be as simple as electrical connect. Trash in valve body. Like stated before, plugged filters, etc.
Temps are higher than normal. I have a stage 4 my temps are around 190 right now. If you drive normal, temps usually are around 100 degrees over ambient temp. (w/out upgraded cooler)
The tranny shop needs to fix this.
Did you, the trans shop, or anyone reset the taps?
Old May 3, 2009 | 06:22 PM
dhardy1357's Avatar
no not that im aware of. he wants me to bring it in to hook up a tech II and fast relearn it. iv heard you can do it in the scan tool part of efi but i dont know how. anyone know?
Old May 3, 2009 | 08:01 PM
when u flash a tune in the ecm there is an option to reset the taps on the box tha comes up
Old May 6, 2009 | 05:46 PM
scramHD's Avatar
Right before the "agreement". Click at the top, the other box, I think its says Taps. You dont have to log onto the Allison controller to do this.
