04.5 cp3 pump
Old Apr 28, 2009 | 12:19 PM
tanda603's Avatar
Default 04.5 cp3 pump
im really at a loss about my truck, while im driving down the hwy, the motor just seems to go dead for a sec then runs fine like nothing happened. the check engine light comes on and when i have it checked it comes up as the cp3 pump regulator control. this has happened a number of times. does this regulator go bad slowly or will it leave me stranded all of a sudden? also is there an aftermarket pump that will fix this problem so i dont have to deal with the factory one? my truck is mostly stock, no chip or anything and about 65k on it thanx for the help
Old Apr 28, 2009 | 12:50 PM
AlCorr's Avatar
May not be the CP3, first thing, what are the codes?
Old Apr 28, 2009 | 01:55 PM
cumminscr's Avatar
lift pump starving cp3 of fuel? i recomend an airdog 100 or fass 95
once i have the funds i will do one as well, can do alotta good to your truck.
tell us the codes
Old Apr 28, 2009 | 07:22 PM
wildbill's Avatar
Regulator controller is aka the FCA. Be on the back of the pump, and be the only thing with a plug on it. Real easy to spot. Good thing is it only costs around $120 from Cummins.
Old Apr 30, 2009 | 07:09 PM
tanda603's Avatar
Default cp3
the code came up as p0251 and said cp3 pump regulator, do these go bad ar is it common for them to go bad at 66000 miles? was also wondering if i should be using a fuel additive for lubrication?
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
moneypitk5
Feb 12, 2015 11:01 AM
B.k. Smith
10
Jan 7, 2015 02:29 PM
