Couple of questions
Old Apr 28, 2009 | 12:25 AM
redneck_cummins's Avatar
Default Couple of questions
Ok guys Ive got some things going through the old nogen and need some input. Im debating on wether to stack the juice with a smarty or add some bigger injectors whats yalls thought on this. If bigger injectors is the way to go what would be the biggest that would be suiteable for towing and daily driving? Now I know Im going to need more air which leads to my next question, what size turbo would I want to run with the juice and larger injectors. Thanks for the help
Old Apr 28, 2009 | 12:30 AM
stkdram55's Avatar
i would go with the injectors,probably wouldnt go much higher than 100hp if you do alot fo towing...then the turbo i would say something like 62/14 maybe a 64
How much do you tow (pounds and how frequently??)
Old Apr 28, 2009 | 12:34 AM
I wouldn't go over 100hp injectors on the stock HY35. Do the Injectors and Turbo at the same time. Either a Phat Shaft 62/65/14, 64/65/14 or Super Phat Shaft 62/71/14 or 64/71/14. Whats your power goals?
Old Apr 28, 2009 | 12:40 AM
Probably around 400 to 450hp. Its very frequently that I do any towing I just dont want to over do it and then end up having to tow something heavy if you know what I mean
Old Apr 28, 2009 | 12:47 AM
stkdram55's Avatar
then some 100 HP sticks, and like a 64/65/14 is what i would go with
Old Apr 28, 2009 | 12:53 AM
You would probably be better with a 62/14 if your going to be towing alot.
Old Apr 28, 2009 | 12:58 AM
Thanks for the help guys .
Old Apr 28, 2009 | 01:06 AM
stkdram55's Avatar
if he aint towing heavy all the time i think the 64 would be alright...and it gives him a little more room to grow
Old Apr 28, 2009 | 01:45 AM
01quadcab's Avatar
I am running what you want then. I have a s300 62/71/14 and ddp 110's. I had some 100hp jammer nozzles when I put out 440 to the rears. I believe I am making more now as I ran 12.9 at the track with the new setup. It tows well and I have an auto. My ddp's actually run way cleaner than my jammers did. 3 of my buddies switched over to ddp's and they are all much happier 2 with 24 valves and 1 12 valve. It's worth it to get a good set of sticks.
Old May 3, 2009 | 08:16 PM
Default Off the subject Question
So I got some info on my truck from the Chrysler Customer Assistance Center and they said that the motor in my truck is the 5.9L TD Eng(ETC), but dodgeram.org says that the ETC engine didnt come out in 99 but in 01-02. So I wouldnt think that is it possible for a 99 model to have a 01 engine in it or would it?Here is the email that I recieved- Dear Andrew:
Thank you for contacting the Chrysler Customer Assistance Center
regarding your 1999 Dodge Ram.
We have reviewed your recent email and we are glad to provide the build
sheet for your Dodge Ram. We appreciate the time and effort you took to
write to us.
In response to your email, we are pleased to provide vehicle build
information as per your request. As per our records, your Dodge Ram was equipped from the factory with the following:
Premium Cloth 40/20/40 Bench Seat
Agate
Light Group
Heavy Duty Service Group
Trailer Tow Group
Heavy Duty Insulation Group
Convenience Group
Power Convenience Group
Monotone Paint
SLT Decor Group
5.9L TD Eng(ETC)/5Spd M/T NV4500 HD(
136 Amp Alternator
750 Amp Maintenance Free Battery
Pwr Disc/Drum Rr Anti-Lock Brakes
Rear Drum Brakes
40/20/40 Split Bench Seat
Front Height Adjust Shoulder Belts
Next Generation Front Air Bags
Passenger Air Bag On/Off Switch
Deluxe Headliner
Front Seat Area Carpet
Front Floor Mats
Passenger Assist Handles
Mini Overhead Console
Trim Parts For 'SLT' CPOS
All Manual Transmissions
5-Speed HD Manual Transmission
Shift-on-the-Fly,241HD Transfer Case
Dana M60/248MM Front Axle
3.55 Axle Ratio
Dana M80 Rear Axle
Anti-Spin Differential Rear Axle
All Engines
5.9L Cummins 24V Diesel Engine
Tinted Glass Windows
Tinted Windshield Glass
Front Door Tinted Glass
Rear Sliding Window
Rear View Day/Night Mirror
Passenger Side Sun Visor w/Mirror
Power Heated Mirrors, Fold-Away
All Vehicles W/Power Mirrors
Air Conditioning
Hood Insulation
Dash Liner Insulation
Deluxe Insulation Group
Instrument Cluster w/Tach
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locks
Power Windows, Driver One-Touch
STRIPE/BADGE/MOLDING/COLOR
Ignition Time Delay Lamp
Map/Courtesy Lamp
Glove Box Lamp
Underhood Lamp
Halogen Headlamps
Fog Lamps
Cargo Lamp
Bright Rear Bumper
Bright Front Bumper
Front License Plate Bracket
Bright Grille
Black Windshield Moldings
Black Tailgate Applique
Removable Tailgate w/Caliper Latches
Front Air Dam
Front Bumper Sight Shields
Federal Emissions
Delete EVAP Control System
34 Gallon Fuel Tank
Engine Block Heater
Speed Control
Heavy Duty Engine Cooling
Light Driftwood Satin Glow
All Radio Equipped Vehicles
AM/FM Cassette Radio
4 Speakers
Fixed Long Mast Antenna
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Tire Carrier Winch
LT245/75R16E BSW All Season Tires
Michelin Brand Tires
16X6.5 Chrome Wheels
Steel Spare Wheel
All Steel Wheels
Center Hub
Pickup Box
Vendor Painted Cargo Box
Transfer Case Skid Plate Shield
Build To U.S. Mkt. Specifications
2 Additional Gallons of Diesel Fuel
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
GVW Rating - 8800#
Zone 61-Atlanta
4X4 Tracking
Virginia Chapter-90 Recovery
Waterbase Paint
Status D1 to D Less 100%
