power screw
Old Apr 27, 2009 | 11:05 AM
jhase's Avatar
Default power screw
alright my power screw is stuck wont turn down or up and i need it loose what can i do
Old Apr 27, 2009 | 08:55 PM
RSWORDS's Avatar
You can remove the top of the case to give yourself more room to work on it. Is it cross threaded? Heas it moved in the past?
Old Apr 30, 2009 | 12:22 AM
jhase's Avatar
no i messed with it once and it just stuck , will a govonor spring give me more power
Old Apr 30, 2009 | 12:37 AM
89silverbullet's Avatar
gov spring just stretches your fueling into higher rpm's. try WD-40?
Old Apr 30, 2009 | 09:32 AM
Begle1's Avatar
The fuel screw doesn't typically stick.
Congratulations, you've managed to find yourself a new problem!
Before I broke the screw trying to get it out, I'd get a new one from the injection pump shop.
If you buy a new one it comes with the handy hex head and no collar. Costs $20.
Old May 7, 2009 | 09:44 AM
jhase's Avatar
cool thanks for the advice and no its not cros threaded i think that its just stuck... flat out it really has enough power i just want my speed really it runs low 15 at track
Old May 7, 2009 | 09:47 AM
RSWORDS's Avatar
A 3200 spring will give you more top end
Old May 7, 2009 | 10:00 AM
jhase's Avatar
thanks and how about that shut off solenoid it keeps going out
and advice
Old May 7, 2009 | 02:11 PM
peobryant's Avatar
and advice
Either turn the pump down, or get bigger injectors. Thats if you want to turn the truck off with a key.
You could always install a pull cable.
Old May 12, 2009 | 11:59 AM
jhase's Avatar
a friend has a set of 375h marine injectors can i put them in it is inercooled and i believe they will fit
Texasboy
5.9L Rotary Performance
Sep 19, 2016 12:06 PM
explorer197143
Dec 28, 2014 01:14 PM
