Down pipes?
Old Apr 26, 2009 | 03:47 PM
chadillac's Avatar
Default Down pipes?
Is it worth while to change my stock down pipe for a aftermarket unit?
Old Apr 26, 2009 | 05:51 PM
torqctd's Avatar
I have been told no.
Old Apr 27, 2009 | 10:29 PM
dalton06's Avatar
I don't see why it wound help. It's the stock muff and cat that restricts. Not the downpipe. Plus to change just the downpipe is a pain in the *** cause the rest of the pipe needs to slide back to get it off then back up onto the downpipe to get it back on. Usually not that much play in the system. Seems pointless to me
Old Apr 27, 2009 | 10:40 PM
raptr85's Avatar
i talked to several guys that deal in diesel performance and they have told me that dodge's downpipes are actually designed well, so there is no need in changing it unless you decide to go with a 5" straight from turbo on out
Old Apr 27, 2009 | 10:53 PM
If your running an Automatic Transmission and decide to replace your Turbo you will have to get a HX40 Down Pipe.
Old May 5, 2009 | 09:11 PM
Stacked03's Avatar
Just do the deletes and call it good if your on a budget!
bajahigh
Oct 6, 2014 07:49 PM
