44lbs of boost
Old Apr 26, 2009 | 03:42 PM
djwhonda92's Avatar
Default 44lbs of boost
how bad is it if i hit 44lbs on my stock turbo.. fyi- it is hitting 44 when i'm floored from 0mph, it actually jumps to 44 from like 35 when it shifts into overdrive
Old Apr 26, 2009 | 04:09 PM
Whit's Avatar
Site Mascot
thats about the max yer head gasket will take................some different than others but yer borderline there
Old Apr 26, 2009 | 07:15 PM
djwhonda92's Avatar
someone told me a stock turbo can only take like up to 35lbs
Old Apr 26, 2009 | 07:26 PM
Lil Red Express's Avatar
ya there only good to 35lbs anything more and your heating the air to much.
Old Apr 26, 2009 | 07:31 PM
djwhonda92's Avatar
ya i hit about 1100 degrees
Old Apr 26, 2009 | 09:44 PM
The intercooler can't cool the intake air enough to make it efficient. I can hit over 1500 with out a problem. Praying for a s300 but first I gotta do the trans.
Old Apr 26, 2009 | 11:32 PM
xzaq103's Avatar
FormerVendor
there good till 40lbs they will do more for a little bit but not for long. After 35psi they make heat not power.
Old Apr 26, 2009 | 11:42 PM
OverPressured's Avatar
40lbs is pushing it with the head gasket too, unless you have head studs.
Old Apr 26, 2009 | 11:45 PM
djwhonda92's Avatar
no i dont have head studs. so i'm taking my truck to a diesel shop tomorrow, do you think they can fine tune it so that it wont hit so much boost??
Old Apr 27, 2009 | 05:56 AM
94 12valve's Avatar
or you could just move the plate and afc housing back and save your self some money
