IAT Sensor Before and After
Old Apr 25, 2009 | 03:03 PM
FormerVendor
Default IAT Sensor Before and After
Finally got around to cleaning my IAT.
BEFORE
AFTER
Think it needed cleaning?
Old Apr 25, 2009 | 03:23 PM
rivercat's Avatar
them exhaust brakes sure do dirty em up! I would clean at each oil change.
Old Apr 26, 2009 | 12:20 AM
FormerVendor
I'm going to clean it atleast at every oil change. Might just clean it once a month. Was going to clean my MAP Sensor but couldn't find my deep socket
Overhead POS has went up 4-5 mpg. I'll hand calculate it next time I refuel.
Last edited by Diesel Dawgs Performance; Apr 26, 2009 at 12:20 AM. Reason: Automerged Doublepost
Old Apr 26, 2009 | 07:24 AM
groceryjunkie's Avatar
What does this sensor do?
Old Apr 26, 2009 | 07:45 AM
stkdram55's Avatar
IAT-Intake Air Temp.
Has to do with the fuel mix, if it is dirty it wont read right and the result can be bad mileage
Old Apr 26, 2009 | 04:20 PM
Whit's Avatar
Site Mascot
I clean mine every 10k......looks just like that too, and when cleaned it idles like a purring kitten
Old Apr 26, 2009 | 07:55 PM
rivercat's Avatar
it reads the air temp at the plenum of the head. In cold weather it triggers the grid heaters and richens the fuel mix. This sensor is only effective during times of low boost. After the charger lights = > 10psi its all in the box actually pretty crude a well tuned 12 valve with a perfectly adjusted plate could actually run cleaner. I belive the ADR box is a big step as it is tunable throughout the fuel curve
Old Apr 26, 2009 | 08:13 PM
Johnny Z's Avatar
Do i have one of those on my 96 12V? and where would it be located and how do i take it out and clean it???? Thanks in advance!
Old Apr 26, 2009 | 08:51 PM
Whit's Avatar
Site Mascot
Yes you do
https://www.dieselbombers.com/12-val...t-diagram.html
https://www.dieselbombers.com/24-val...at-sensor.html
Old Apr 27, 2009 | 12:51 AM
FormerVendor
Throttle response has improved. I now notice that on my Pulse the IAT and Coolent Temp match at startup now.
