Anyone running aeroturbine w/ stacks
Old Apr 25, 2009 | 03:01 PM
rivercat's Avatar
Default Anyone running aeroturbine w/ stacks
I happen to think this would be the ultimate exhaust. The aero- as far as scavenging and reducing egts- works better closer to the heat. I figure downpipe then aero then flex to 90 then y then both 90s and stacks would be a heck of a setup. Seems like the aero is good for taking the drone out and leaving the turbine whisle, if I remember correctly from other posts long ago.
are stacks bearable with no muffler?
Old Apr 29, 2009 | 04:53 PM
rivercat's Avatar
wow no one using both what about just the aero comments is it worth the money?
Old Apr 29, 2009 | 05:08 PM
torquey's Avatar
i run a 5'' single stack and was wondering the same thing,someone told me the aero would be the way to go.
Old Apr 29, 2009 | 08:02 PM
JLWelding's Avatar
I run duel 5" stacks, I built my own spliter for the back of the truck.No drone or should I say not as much, built out of 8x3 rectangle. What is a aero.
Old Apr 30, 2009 | 10:23 AM
torquey's Avatar
aeroturbine is a muffler brand.
Old Apr 30, 2009 | 10:33 AM
94cummins12v's Avatar
why would you want a muffler on a diesel with stacks
Old Apr 30, 2009 | 10:46 AM
stkdram55's Avatar
if you have an extended cab the noise aint bad, and also if you make a box instead of using a y pipe in your truck like stated above...it will make it less droney
Ronnyg
Dec 16, 2015 06:37 PM
ROCKITV8
Jun 17, 2015 08:38 AM
tim12valve
May 29, 2015 05:19 AM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
carid
Jan 12, 2015 04:32 AM
