shut off solenoid
Old Apr 23, 2009 | 08:10 PM
cumminskid92's Avatar
Default shut off solenoid
i think my shut off solenoid is bad. is there a way to check it.
Old Apr 23, 2009 | 08:42 PM
921stgen's Avatar
Does it shut the truck off?
RSWORDS's Avatar
jump 12v to it and listen to hear it click.
Whats it doing?
Old Apr 23, 2009 | 10:59 PM
peobryant's Avatar
Why do you think it is bad? If the truck starts up, and shuts off then its fine.
If not, then do exactly what RSWORDS said do. You should hear a click with 12V.
Old Apr 24, 2009 | 11:25 AM
jhase's Avatar
my shut off switch keeps goin out whats goin on with that it chips then my truck wont turn off???
Old Apr 24, 2009 | 07:13 PM
it was the soleniod. my truck would not start. i ordered a new one and it fixed it
Old Apr 25, 2009 | 11:15 PM
peobryant's Avatar
Is your pump cranked with stock injectors?
Old May 7, 2009 | 09:47 AM
jhase's Avatar
yes it is
Old May 7, 2009 | 02:15 PM
peobryant's Avatar
If you crank up a pump (especially with an intercooled truck) with stock injectors, it puts a lot of pressure on the pump. With the small intercooled injectors, the pump won't flow enough fuel to release some of the pressure, and blows the tip off of the shut off solenoid.
One fix is to get bigger injectors, and that will relieve the pressure on the pump. The other solution is to back off of the fuel screw.
I would go for the bigger injectors.
camp9
Mar 25, 2017 07:40 AM
bosse777
Sep 28, 2015 05:38 AM
cdhearn
Chevy/GMC Duramax 01-04 LB7
Jun 17, 2015 11:15 AM
nevadagramm
Oct 17, 2014 07:59 PM
pstack
Oct 16, 2014 04:25 PM
