4BT LTD 55 MPH Question?
Old Apr 23, 2009 | 01:23 PM
Prankster's Avatar
Question 4BT LTD 55 MPH Question?
I just can't break the 55 MPH speed barrier.
Yes, I have low rearend gears: but I changed my wheels from 19.5" to 16."
Did I just make things worse?
Auxiliary Transmission?
Overdrive/Underdrive Units?
I would like to reach 85 MPH for the highway, and Interstate.
Is changing my rearend gears my only option?
How tall is too tall?
I would still like to be able to tow a trailer when needed.
__________________
Old Apr 23, 2009 | 02:01 PM
Red_Rattler's Avatar
High Tech Redneck
If you went with a smaller tire size which I'm sure you did with a 16" rim, yes you made the gearing lower in fact. What rearend is in this thing? Regearing would be wayyyy cheaper than an aux unit for the trans. Whats the factory gearing?
Old Apr 23, 2009 | 06:03 PM
Grider Pirate's Avatar
Are you running out of RPM? If that's the issue, you need taller gearing or taller tires. If you just don't make the horsepower to break 55 mph, something's probably not right withthe 4BT.
Old Apr 24, 2009 | 06:27 PM
Prankster's Avatar
I'm still working on an answer. I told the shop not to set the trani over on the bellhousing but I think the did it anyway, and bent the input shaft.
Old Apr 26, 2009 | 12:53 AM
89silverbullet's Avatar
i would put some bigger taller tires on it and do some regearing. nice heeler pic you got there.
Joracing3
Sep 10, 2016 05:28 PM
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
