EGR??
Old Apr 23, 2009 | 12:54 AM
djwhonda92's Avatar
Default EGR??
what is the EGR?? a guy i know was trying to explain it to me but he wasnt completely sure either. is there modifications i can do to it??
Old Apr 23, 2009 | 01:03 AM
Red_Rattler's Avatar
High Tech Redneck
Exhaust gas recirculation. Since yours is a Cali truck it should have it. Its a hose that comes off of the exhaust manifold and connects back into the air intake. The system takes little amounts of exhaust gases and sends it back in the intake to be reburned. IE: producing cleaner exhast emissions. But since your truck is modded now, you can get a block off kit for it since its not needed.
Old Apr 23, 2009 | 09:12 AM
djwhonda92's Avatar
where have you seen a block off kit
Old Apr 23, 2009 | 11:04 AM
High Tech Redneck
Best way to do it is get a old 12v 49 states manifold or and aftermarket one. Then you either fab up you own block off plate for the air horn, or upgrade to a after market one as well. Then just disconnect and block off the vacuum lines. Some haven't had the check light come on some have, so he's a diagram for a fooler if it does.
Old Dec 13, 2022 | 02:55 PM
Boots6.6Duramax's Avatar
Default 12v cummins questions???
Hey i was trying to check out the diagram for if you throw a code. I cant seem to find a pic or file on your post. currently wanting to do an egr delete on a 51 chevy dropped onto a 1998 dodge chassis with a 12v cummins in it.what will this effect with blocking off the vaccume lines. Obviously i dont wanna damage anything. This is the first cummins ive worked on so id like to gain some knowledge first. ANY info is greatly appreciated... [/QUOTE]
Old May 7, 2025 | 02:30 PM
Benrochat's Avatar
The EGR valve on a 12v Cummins engine is typically located on the front of the intake manifold, near the front of the engine. It's connected to the EGR cooler>> and is often near the height of the turbo
syctaz
Jun 26, 2015 12:20 PM
kestmic1
Jun 8, 2015 12:44 PM
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
Bighouse
Apr 9, 2015 06:51 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
