runnin two stroke oil?
Old Apr 22, 2009 | 09:28 PM
bowtech's Avatar
Default runnin two stroke oil?
why do you do that? what kind of oil any two stroke? wat ratio? pros? cons?
Old Apr 22, 2009 | 09:30 PM
94cummins12v's Avatar
it better lubricates the pump. but in our case its not needed because our pumps are lubricated off the engine oil. i run it just becasue i get it for a cheep price, i run 1 qt to 35 gallons really no cons except the price, pros, like i said lubrication. i would run like a super outboard 2 stroke or a synthetic just becasue ther better quality
Old Apr 22, 2009 | 09:38 PM
bowtech's Avatar
does it smoke more?
Old Apr 22, 2009 | 09:39 PM
i havent noticed a difference between more or less smoke, why do you want more smoke
Old Apr 22, 2009 | 09:53 PM
bowtech's Avatar
no dont need any more
Old Apr 22, 2009 | 10:05 PM
good choice. anywho i havent noticed a difference in smoke with running it
Old Apr 23, 2009 | 01:01 AM
djwhonda92's Avatar
you guys are all so lucky and you dont even know it. in California we can get "smoke tickets" first offense is $800
Old Apr 23, 2009 | 01:30 AM
AABEAR's Avatar
I have found the best price at Wal-Marts super TECH TWC-3 Mix 1Oz per gal..
Old Apr 23, 2009 | 01:37 AM
hereismylife's Avatar
I ran about anything through my tank. the 2 stroke oil will quiet the engine down and will lube the system. Also you should not get any smoke unless you put to much in
Hope this helps
Old Apr 23, 2009 | 12:50 PM
bowtech's Avatar
im runnin the grey bottle of the diesel kleen would it be better to use two stroke oil?
