no warm air
Old Apr 21, 2009 | 08:33 PM
fastfreddie's Avatar
Default no warm air
hey dudes i have an issue with my diesel it wont blow really hot air. i changed the thermostat, flushed out the coolant system reversed it also put in new antifreeze. it wasn't even dirty. i was thinking when it is up to operating temp maybe the doohicky that controls the water temp is not opening all the way or. may be where the hot coolant line comes off the engine is at the half way point on the head ,when from past experience it should be beside the thermostat no. ive had this truck for 2 years now and it comes to the point where i wont drive it in the winter cause its so cold just warm air not really hot like the way it should be now thats springs hear it still warm not hot. even at warm outside temps.
any one have a similar problem with there wheels oh yeah i have a 1999 diesel
Old Apr 21, 2009 | 08:38 PM
Red_Rattler's Avatar
High Tech Redneck
Heater core could plugged
Old Apr 21, 2009 | 09:42 PM
Tweaker727's Avatar
Simple test !
Bring the truck up to running temp, and grab one side of the heater core lines, they should both be hot !
If not, it's a heater core... if they are both hot, then it's more than likely a " Blend " door issue, does it get cold air ( A/C ) when you ask for it ?
Cain379's Avatar
I agree, I had the same problem and it turned out that the heater core was totaly screwed. Make sure to check for any leaks inside the cab, that will tell you for sure that its the core.
Old Apr 23, 2009 | 11:10 PM
torquer's Avatar
heater core definately
Old Apr 23, 2009 | 11:13 PM
cashwheel's Avatar
Originally Posted by Tweaker727
Simple test !
Ditto, heater core or blend air door, most likely blend air door.
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
sjcdep08
Nov 12, 2014 07:05 PM
