Killer Dowel Pin?
Old Apr 21, 2009 | 02:25 PM
Brother Hogg's Avatar
Default Killer Dowel Pin?
So recently I've noticed a new sound from the front cover of my truck. Sounds like a pebble being tossed around inside the front of the engine. The sound does not keep time with the engine and does not pick up speed when you rev the truck up. It is not a steady click, reminds me of a pebble in a clothes dryer. When I listen to it, it's easy to imagine something bouncing around inside the front of my engine.
I bought the truck used so I do not know if it has ever had a KDP kit installed. The front cover does leak oil.
To date, I've replaced the water pump, thermostat, all cooling hoses, the fan clutch, lift pump, rebuilt the transmission, and right now I am in the middle of replacing the head gasket. Seeing as how the front cover is leaking, I thought I might just pull it and see if there was a KDP kit on it.
What say ya'll?
Old Apr 21, 2009 | 02:38 PM
c0zgrove's Avatar
i would pull the cover and see it sounds like the kdp fell out your lucky it hasnt got caught inthe gears causing a bigger problem imo i wouldnt even think about runnig the truck till you check that out
Red_Rattler's Avatar
High Tech Redneck
For sure pull it open!!! Good luck
Old Apr 21, 2009 | 02:42 PM
sstockton's Avatar
Yep, pull it open ASAP.
Sean
Old Apr 21, 2009 | 05:36 PM
392hemix's Avatar
That was the first thing i did to my truck b4 i even registerd it. i would recomend it
Old Apr 21, 2009 | 05:49 PM
navalseabee's Avatar
i also agree. it sonds like you got majorly lucky if it is the pin. i just did mine in the parking lot where i live.i can breath easier now
Old Apr 21, 2009 | 08:18 PM
Beets's Avatar
That is something not to wait on. i thought my truck was fixed well after 1800 parts and labor when it fell out i know it is now. i wish i would have just double checked it
Old Apr 22, 2009 | 09:36 AM
Thanks guys, I'll keep you posted on what I find, won't be able to start on it until this weekend.
Old Apr 22, 2009 | 03:42 PM
12valvetater's Avatar
it could also be the bolts that hold the case on they like to fall out make em tight and put red lock tight on them and tight means right before they strip out cummins torque spec isnt enough.
Aug 25, 2015 07:10 PM
windage
Jul 17, 2015 12:45 PM
Weeks327
May 11, 2015 10:43 AM
359ci12v
Apr 9, 2015 08:24 AM
dieseldeal
Mar 24, 2015 12:11 AM
