New Turbo
Old Apr 20, 2009 | 08:17 PM
relay93's Avatar
Default New Turbo
Well the new turbo arrived today, thanks goes to Luke @ Diesel Dawg. I am still running the stock exhaust so I will have to purchase a 4" to 3" adaptor before starting the install. I really do not want to use the standard type of u bolt clamps. What do you use? I was thinking of locating some type of spring clamp but I don't know if these will work do to the slip fit of the adaptor.
I have to take my truck back to the painter for some spots hopefully he will have the truck for a few days. I still need a 4k gsk, I will only use the 3k portion of the kit. Hopefully I will make it to Springfield, Mo.
Thanks for the conversation the other day Jamie Wood and you to Luke.
Have a great evening.
Old Apr 20, 2009 | 08:19 PM
94cummins12v's Avatar
this thread is worthless without pitures. what ya get
Old Apr 20, 2009 | 08:41 PM
relay93's Avatar
I got a BD Super B.
Here a few images:
[IMG]https://www.dieselbombers.com/members/relay93-albums-96-4x4-picture4145-img-0815.html[/IMG
https://www.dieselbombers.com/member...-img-0817.html
I'm not sure how to post pics
sweet deal
Old Apr 20, 2009 | 08:45 PM
relay93's Avatar
Default Install
For those of you that have purchase this Turbo did you have to clock or was it a direct install?
Any install advice is welcomed.
TIA
Old Apr 20, 2009 | 09:34 PM
the turbo should be direct bolt on
four nuts holding the turbo on =15mm box end wrench. v-band flange clamps =11mm socket, cresant wrench for the oil suply line and scrap the turbo oil drain line and rig up a high temp heater hose (blue hose with red inside) so you can direct it anyway you want
Last edited by 94cummins12v; Apr 20, 2009 at 09:34 PM. Reason: Automerged Doublepost
Old Apr 22, 2009 | 09:36 PM
relay93's Avatar
I located A 3" to 4" adaptor plus some wideband clamps, locally, so I can install the new down pipe to the stock exhaust. Hopefully this weekend I will get to install the SuperB and re-install the #10 fuel plate. Could be a great weekend.
Old Apr 22, 2009 | 09:40 PM
snap some pics if posible
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
