can anyone answer this one
Old Apr 20, 2009 | 04:18 PM
richie waddell's Avatar
Default can anyone answer this one
just wired up a smoke switch on my 06 today, and when i push the switch instead of it telling the monitor on the edge w/ attitude that the boost is 0 it actually set the high boost alarm off which i have set at 45psi, it does not throw any codes and does smoke pretty well, is this normal with the edge on the 4 wire map sensors. i used wires c and d to make up the connection, any suggestions or has anyone heard of this before
Old Apr 20, 2009 | 04:32 PM
chadillac's Avatar
I really could not tell you though but i have heard bad things about the smoke switch.All that i have heard was it screws up the map sensor or something like that.I would highly recomend getting rid of the smoke switch.
Old Apr 20, 2009 | 05:11 PM
connermcpherson's Avatar
? got me on that one. worked well on my 2nd gen
Old Apr 20, 2009 | 05:34 PM
07redsled's Avatar
if your edge reads boost off ther map it will read high cause the switch tells the map it has full boost allowing the full fueling there for your high boost reading. also i too have heard a lot of bad news on the 3rd gens with smokeswitches
Tazpal15
5.9L Rotary Performance
30
Jun 29, 2015 07:44 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
SMatyac
Nov 28, 2014 03:58 PM
scd2747
Oct 7, 2014 02:56 PM
