extra fuel tank
Old Apr 20, 2009 | 10:03 AM
c0zgrove's Avatar
Default extra fuel tank
hey everybody my dad just gave me a 100 gallon tank for the bed of my truck and i was wondering if it would be a good idea to set it up on a gravity feed to my main tank
thanks for any input
Old Apr 20, 2009 | 11:19 AM
BEERPLAY's Avatar
JUST MAKE SURE ITS GOT A GOOD SEAL AND NO AIR GETS IN ANYWHERE
Old Apr 20, 2009 | 11:30 AM
94cummins12v's Avatar
you can either do it gravity feed or you can go to a local parts store and pick up a 12v pump for less than $50
Old Apr 20, 2009 | 11:40 AM
c0zgrove's Avatar
do you guys think i sould put an inline filter for it or just let my filter do the work
Old Apr 20, 2009 | 01:03 PM
AABEAR's Avatar
Yes you should. If it sets in the sun it has a very good chance of getting allergro in your tank. So put a good filter on it. I have one on my tank and was glad when the allergro showed up.I use a 12V farm pump it comes in handy if you need some fuel for somthing else.===Good luck
Old Apr 20, 2009 | 07:41 PM
get your self a fernace fuel filter with a clear housing to see crap inside it
hard line it in with galvanized fittings close to the pump
Last edited by 94cummins12v; Apr 20, 2009 at 07:41 PM. Reason: Automerged Doublepost
Old Apr 20, 2009 | 08:20 PM
c0zgrove's Avatar
94 what extacly do you mean by a fernace filter and what pump do i need to use galvanized fitting on
Old Apr 20, 2009 | 08:26 PM
go to a store that carries a furnace oil filter set i work at a hardware store and sell them but i dont know of were else you would get them other than like ziggys or whoever sells oil furnace parts. you can get 12v pumps that are just inlie for like $50 or you can get an actual sliptank/ farm pump for about $300 that uses pipe fittings. come off your tank with pipe fittings to your filter then streight into your pump after that. most guys around here that do it put a 3" pipe nipple between the two to make the filter as close to the pump as posible
Old Apr 20, 2009 | 08:27 PM
Beets's Avatar
if you run a 12v pump it is a lil easier to fill it with red fuel...
Old Apr 20, 2009 | 08:30 PM
ecaclty, up here if you have a lifted truck with a slip tank in it, you have gotten pulled over and dipped at one point in time. ive been dipped twice since ive owned this truck a year and a half
