small mods
Old Apr 18, 2009 | 10:51 PM
94 CuMmInS's Avatar
Default small mods
my 94 cummins is stock that i no of and wanna no whats some things i should do to get lil more power and maybe lil more smoke without wrecking tranny or anything else? whats small things i can do?
Old Apr 18, 2009 | 11:14 PM
BlackGoat's Avatar
for 50 dollars buy a k&n cone filter that way you can use the stock air tube and a zip tie you save 250 dollars.cut the muffler and cat out and replace with straight pipe.move your fuel plate forward.take out the turbo silencer reducer you will be able to here the turbo more and it will alow more air to enter the turbo.
Old Apr 19, 2009 | 12:03 AM
94 CuMmInS's Avatar
soo pretty much just make more air flow . movin the fuel plate forward wont damage anything will it
Old Apr 19, 2009 | 12:04 AM
DB Admin's Avatar
Banned
use at your own risk ...or your transmissions hehehe
Old Apr 19, 2009 | 12:07 AM
94 CuMmInS's Avatar
saying my trannys gonna go if i do?
Old Apr 19, 2009 | 12:11 AM
DB Admin's Avatar
Banned
chances are if you have a stock torque converter your trannys going to go sooner or later ...sooner if you let the tamed beast under the hood off the chain . if you plan on having your truck for a long time then you need to consider that the CTD in stock form is detuned to keep the dodge around it in 1 piece . and bomb wisely get gauges first , then a big converter and tweaked VB , then you can give the chain some slack
Old Apr 19, 2009 | 12:14 AM
94 CuMmInS's Avatar
ooo alright so gauges, big converter, and build vb. then move on to other things
Old Apr 19, 2009 | 12:21 AM
DB Admin's Avatar
Banned
thats the smart way to go about it , theres a big difference between spending money on your truck because you want to and spending money on your truck because you have to .
Transgo TFOD shift kit in your VB and a Big Single Disk will do most people , pyro and 60# boost are the only gauges you need , Then you can have some fun
Tab your KDP too
Old Apr 19, 2009 | 12:25 AM
94 CuMmInS's Avatar
alright man thanks alot for the info
2004LB7
29
Feb 29, 2016 06:00 PM
May 8, 2015 08:30 AM
rtbcoop
Dec 30, 2014 02:13 AM
Nov 1, 2014 04:20 PM
Bslamb
Jeep Liberty
Oct 6, 2014 09:18 AM
