stupid front end
Old Apr 18, 2009 | 03:27 PM
oglejust's Avatar
Default stupid front end
well i torn into my neglected front end today to change the original rotors, i finally got the passenger side out and realized my u joint was broke, the wheel bearing has some play and the ball joints r bad... i still havent even torn into the other side yet either. soooo im gettin 4 ball joints, 2 u joints at least 1 wheel bearing and i need the end of the axle on the driver side. this is gonna be expensive btw what a pain in the a$$ to get the axle out
Old Apr 18, 2009 | 06:05 PM
94cummins12v's Avatar
yes it is they are a pain in the ***. your looking at $200ea for wheel bearings, $25ea u-joint, depending were you go for roters there about $150ea, ball joints i spent $90 on uppers and $80 on lowers, and the shaft will run ya about $250 new
Old Apr 18, 2009 | 06:54 PM
392hemix's Avatar
you musta got cheap u-joints, i paid 60 bucks for mine.....these front ends suck to work on but once you do it you figure out the tricks to make it go easy. I think paid around 600 bucks per side for everything. but now it works great......make sure your carefull when you put your axle shaft back in. I musta ripped it, cause i put everything back togeather and now have a nice leak..
Old Apr 18, 2009 | 07:32 PM
oglejust's Avatar
i found wheel bearings for 120 a piece, ball joints for 50, 25 each for ujoints, and ive already got the rotors and pads. i havent looked up the shaft but i no its gonna suck, hopefully better that 250 tho
Old Apr 18, 2009 | 07:51 PM
DB Admin's Avatar
Banned
the $120 wheel bearings must not be the same , mine had the ABS sensor built in to it and was very pricey
Old Apr 18, 2009 | 08:15 PM
ya the ones without abs are cheeper but up here the cheapest ive been able to find were $189 each. as for the u-joints i work at a hardware store that sells autoparts and get them at a discount
Old Apr 18, 2009 | 11:06 PM
oglejust's Avatar
ya i work at a dealership so i get a discount, it doesnt have abs so no wss's
Old Apr 19, 2009 | 10:22 PM
12valvetater's Avatar
Get the ems lockout hub kit and CAD delete 1400 for everything and it was the best thing ive put on so far.
Old Apr 19, 2009 | 11:00 PM
you wont catch me putting one of them on my truck, way to expensive, i like my homade kit myself, cheep easy and works just as good as those do
Old Apr 20, 2009 | 07:17 AM
GRI's Avatar
GRI
you made a lockout hub kit? if so, do tell.
I know about the home made CAD delete.
