new injectors NEED MORE AIR...conical filter??etc
Old Apr 17, 2009 | 11:16 PM
will1am's Avatar
Default new injectors NEED MORE AIR...conical filter??etc
after putting some mild injectors on the truck it is now smoking more than before and i think its time to start thinking about increasing the amount of air i can get into the engine.
what are some things i can do?i read thier is A PAPER ELEMENT by napa i can get .
and then maybe gutting the heater grid and getting a bigger exhaust.
anybody know where i can get a paper conical filter?
thanks
Old Apr 18, 2009 | 12:58 AM
djwhonda92's Avatar
well i know that napa does sell that BHAF for like $70 but then you have to construct a tube to hold it in place
Old Apr 18, 2009 | 01:46 AM
xzaq103's Avatar
FormerVendor
vulcan has the best price on BHAFs.
How much smoke are we talking?
Old Apr 18, 2009 | 01:53 AM
I would go with a washable BHAF myself. Both AEM and AFE make them, and they are non-oiled filters
Old Apr 18, 2009 | 04:26 PM
MotorOilMcCall's Avatar
Something tells me its time for a new turbo... A filter isn't gonna make much of a difference in reducing smoke on a turbo diesel.
Old Apr 18, 2009 | 06:21 PM
94cummins12v's Avatar
depending on what size injectors you went with and the amount of mods you have done to the pump a turbo will be needed, a air filter and exhasut wont make that much of a difference
Old Apr 19, 2009 | 12:33 PM
bowtech's Avatar
i thought the stock turbo was good to like 450 500 hp?
Old Apr 20, 2009 | 11:49 AM
MODEL70's Avatar
GO WITH A BHAF AND A 4" EXQUAST IT WILL MAKE A BIG DIFFERANCE YOU NEED MORE AIR TO MIX WITH THE EXTRA FUEL YOU ADDED AND YOU NEED BIGGER EXQUAST TO GET BETTER FLOW OUT AS WELL THOUGHS ARE THE FIRST 2 THINGS YOIU SHOULD DO BEFORE ADDING MORE FUEL. THE BHAF FLEETGHUARD # IS AH19037 AND IF ITS THE SAME AS A 98 TRUCK IT WILL FIT RIGHT ON THE STOCK INTAKE PIPE YOU WILL JUST HAVE TO COVER SOME AC LINES AND THE BOLTS FROM YOUR STOCK AIR BOX FOR RUBBING REASONS.THERE ARE ALSO TEMPLATES FOR THE HEAT SHEILD FLOATING AROUND. AND YES THERE IS A LIMIT TO THE STOCK TURBO BUT IF AL YOU HAVE DONE IS A SET OF INJECTORS AND ARE STILL RUNNING THE STOCK AIR INTAKE AND EXQUAST THEN THEY MUST BE REPLACED.
Old Apr 20, 2009 | 01:39 PM
will1am's Avatar
i am looking to get a paper element filter I dont want a cotton/guaze filter
interesting tests below
Air Filter Filtration Test
Old Apr 20, 2009 | 03:42 PM
MODEL70's Avatar
THE FLEETGUARD AH19037 IS A PAPER FILTER AS ARE MANY OF THE OTHER BHAF'S
