04.5 water pump?
Old Apr 17, 2009 | 11:38 AM
sillyneck's Avatar
Default 04.5 water pump?
I thought it was my a/c failing when there was just some brown crap here and there.
Then this morning I drove my truck to work and it's just dumping what appears to be coolant from the front of the motor... and my best guess is the water pump. it's only at 100k miles.
Is this abnormal?
Old Apr 17, 2009 | 07:01 PM
wildbill's Avatar
Some get 150k, some get 40k. If the coolant looks something other than orange, I'd do a system flush. Then a new water pump and all new coolant hoses.
Old Apr 18, 2009 | 10:00 AM
sillyneck's Avatar
are the pumps really as cheap as I've seen or is there something I'm missing? $35 on ebay? I won't buy it there but that's all I've seen for prices. thanks for the reply
Old Apr 19, 2009 | 02:41 PM
MRaynor's Avatar
I found this for you. Not as cheap as you found though.
https://www.dodgeparts.com/oe_parts_catalog.html
Old Apr 23, 2009 | 12:07 AM
10acboy's Avatar
My 04.5 has 105k and is starting to leak some radiator fluid from the front. I had it checked at the Dodge dealership and they were going to charge me about 750 for an OEM water pump (12 month/12k miles warranty), an antifreeze flush and serpentine belt (plus the labor). I stopped by Autozone and picked up some antifreeze, the belt, the water pump (limited lifetime warranty), and a 190 degree thermostat for $135. I'm not a mechanic, but I'll play one this weekend Wish me luck.
Old Apr 23, 2009 | 12:10 AM
Red_Rattler's Avatar
High Tech Redneck
Mine made it to 100K.. Its 3 bolts, easy as pie
Old Apr 25, 2009 | 09:01 AM
JTProuhet's Avatar
you'll be fine just take your time and you'll get it.
Old Apr 25, 2009 | 08:10 PM
elephantrider's Avatar
here is a real quick write up i did on replacing the
water pump and thermostat on an 04.5.
its only two bolts and is very easy. remember to
remove the factory airbox for easier reach-in on
the water pump bolts.
https://www.dieselbombers.com/5-9-li...placement.html
HighVoltageHero
Apr 23, 2015 10:54 PM
klein444
Mar 8, 2015 08:19 AM
moneypitk5
Feb 12, 2015 11:01 AM
Lawrence D. Sanders Sr
Dec 16, 2014 11:52 PM
mpcampers
Dec 4, 2014 08:24 PM
